T.V. cable
Old Jan 14, 2003 | 08:27 PM
forever3's Avatar
Car: 88 IROC
Engine: 5.7 L98 TPI
Transmission: 700 R4
T.V. cable
I know this may sound stupid, perhaps I'm brainfarting here, but what is the proper procedure for adjusting the TV cable? I've done this before on a 3rd gen car and a Chevy Truck, but for some reason, this one isnt acting quite right. Seems I cant get it just right... I dont think I have any other tranny problems, but you never know. I need to make SURE I have this cable right before I start tearing apart and modding a perfectly good tranny.
Old Jan 15, 2003 | 12:45 AM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
I am assuming that you have tried the procedure listed in the tech articles. If not here it is: https://www.thirdgen.org/newdesign/tech/detent.shtml
What is the problem that makes you want to adjust the cable? FYI, I have used the procedure in the tech articles but my transmission always shifted too late. But see it that procedure works for you.
Old Jan 15, 2003 | 07:11 PM
forever3's Avatar
Car: 88 IROC
Engine: 5.7 L98 TPI
Yep, see that is what I thought, but for some reason, I was second guessing myself. Yeah, I did look at the tech article, and did just what it said, which is what I did in the first place, but I'm like you, it shifts too late. It seems to shift too soft alot of times, and it was acting like the TV cable was set wrong. I think my next step will be to try synthetic tranny fluid and go from there. thanks for the input.
Old Jan 27, 2003 | 10:23 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
I just installed the Corvette Servo kit into my 700R4 and my late shifting seems to have gone away.
Old Jan 28, 2003 | 06:05 PM
forever3's Avatar
Car: 88 IROC
Engine: 5.7 L98 TPI
Glad to hear it. How hard and how expensive is the corvette servo to install?
Old Jan 30, 2003 | 01:11 AM
jfreeman74's Avatar
Car: 1985 Iroc-Z
I installed mine myself. The only problems that I ran into was trying to get the cover on and off. That was quite a PITA. You will also have to pull the crossmember off and lower the transmission a few inches to be able to get everything out. I would not pay anymore than $30 to have it installed and I don't think you would be able to find someone to do it for only $30. So my advice is to get a crowbar and install it yourself.
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
