What size rear gear do I have?
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
What size rear gear dso I have? I know its a 2.73 posi but what size is it 8.5 or 7.5/8 and if I wanted to change from my 2.73 to say 3.42 would I just need to change out the ring and pinion gears?
thanks
thanks
forgot a pic...
what do you mean the whole housing? its a 10 bolt if that helps? and when you say limited slip,,,thats posi for Chevy right? cause when I have it raised in the rear and turn one wheel the other turns in the same direction....if that matters..
Car: Take
Engine: Your
Transmission: Pick
Limited slip, posi, yada yada yada... Its all the same.
As for the whole housing, I just wanted to see the shape of the pan gasket, but if its out of a thirdgen, and had 10-bolts, then its the 7.5/7.65" rear axle.
If you want to upgrade to 3.42s, then you have two options. You can either get the Richmond Gear 3.42s specialy designed for "2" series carriers, or buy a "3" series carrier and standard 3.42 gears.
what kind of carrier do I have? Can you tell what I got just from the picture?
thanks for the info..
Car: Take
Engine: Your
Transmission: Pick
What kind of carrier? Well, since you said yourself it had 2.73s, then its a "2" series carrier.
As far as Eaton -vs- Auburn, Eaton did make Posi's that look like that, but I don't think they were installed in 3rd Gen's. I think the only Eaton limited slip installed in 3rd Gens (early ones at that) were more of a locker style. So my guess would be an Auburn which used Cones instead of Clutches.
hectre13
Dec 11, 2023 08:14 AM
toronto formula
Nov 10, 2015 06:17 AM
hectre13
Aug 26, 2015 08:17 AM
knight72
Aug 10, 2015 09:32 PM
