Posi Rear End
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
Posi Rear End
I have a Stock 10 bolt 3:73 rear end, however its not a posi, what will be the best way to convert this to a Posi 3:73 Rear End.
"I want this baby to Hook"
Thanks: David
Thanks: David
Can anyone answer this with a logic explanation ...
Car: 82 Pace car
Engine: Small block
Transmission: TH350
DUDE!!! OPEN UP A JEG"S AND BUY A POSI!!!! open the box when it comes and install it in your rear end-----It doesn't get any more logical!! BUT maybe I'm misunderstanding you so pardon my sarcasm. I'm just trying to help.
Here is the Info:
84 Z28 Camaro 305HO
REAR END GEAR: (6EB 0339/22522676) 3:73- (41:11)teeth
Hope this will shed some light.
84 Z28 Camaro 305HO
Car: 4
Engine: 6
Transmission: 5
Not too much you can do, other than come up with a posi carrier and install it. Pretty straightforward, no shortcuts or magic tricks I know of, but quite easy just the same. Even I can manage it, so it has to be easy.
Just avoid the ones that come in S trucks; they're easy to spot, they have little weights in them. They're made by Eaton, who calls them Gov-Lock; the rest of us call them Grenade-Lok. And of course, make sure that the posi carrier you get, is for 3 series gears, not 2 series. 2 series is 3.08 and lower, 3-series is 3.23 and higher.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
