3:42 or 3:73
Old Feb 1, 2003 | 09:17 AM
white91Z28's Avatar
Car: 1991 Camaro Z28
Engine: TPI 350
Transmission: 700R-4
3:42 or 3:73
I am thinking about getting some gears for my car. Currently I have 3:23 and with the modifications that I have made you can see in my sig, which should I go with for best performance 3:42 or 3:73.
Old Feb 1, 2003 | 11:00 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Welll...... Purely performance based .... 3.73's
You might not notice a difference from 3.23 to a 3.42 ....
go with the 3.73's
Old Feb 1, 2003 | 02:57 PM
MdFormula350's Avatar
i am also thinking 3.73's.
Old Feb 1, 2003 | 05:21 PM
Damien00677's Avatar
Car: 2006 'Nox 91 Camaro RS 91 1500 Silv
Engine: GM 3.8L, 305 SBC, 350 SBC
Transmission: Auto, auto, auto
I was reading on a tech page that my car, an 89 RS, only came with 3.42 gears. Is this right? and if so..would it be worth my time to change them to 3.73.
Old Feb 1, 2003 | 06:15 PM
palric's Avatar
Car: 90 IROC 5.7 hardtop
Transmission: T5 swap
Axle/Gears: Yup -- they still work
I currently have factory 3.42s in a '91 Formula.
I've tried 3.08 to 3.42 to 3.73 swaps on my last 3rd gen. For my current 3rd gen I bought a set of Richmond Gears 3.73s and will be replacing the 3.42s in the spring. I find the 3.73s work best with the T-5.
my .02 cents worth,
RP.
Old Feb 2, 2003 | 06:51 PM
Justin 87 GTA's Avatar
Car: 1987 GTA
Engine: 645hp/656 ft lb Blown 383
Transmission: 700-R4 3,000 stall
Axle/Gears: 3.55 moser 12-bolt
Best gear ratio depends on your setup, speeds/gear through trap, torque converter, engine, hp, torque, type of power adders, rear tire diameter and what you want the car to do. Figure all of this out first. The taller gears don't alwasy make you go faster. Especially when you are out of the powerband or in the wrong gear through the traps. Lingenfelter uses 3.42's/3.45's on many of his customer's 3rd and 4th gens. I like my 3.45's. is it worth changing from 3.23 to 3.45? Probably not. I would alter one of the other factors, that will cost you less, or build your setup to match 3.73's and then get them. Just my opinion.
PurelyPMD
May 5, 2016 04:57 PM
loud91rs
Oct 5, 2015 10:05 PM
Prodigious
Sep 18, 2015 05:23 AM
Prodigious
Sep 18, 2015 05:18 AM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
