th 400 kick down switch...
Old Feb 1, 2003 | 09:53 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
As far as I know you are supposed to just hook up a 12 volt source to this. Now I am finding out that there is a switch that should be mounted near the carb or on the gas pedal.
Could someone please explan how this works and how it should be hooked up properly.
Kat
Old Feb 1, 2003 | 10:07 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Hrmm found this on summit...
http://store.summitracing.com/partdetail.asp?part=12453
Kat
Old Feb 1, 2003 | 10:13 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Cars that came with 400s used to have a switch mounted on teh gas pedal bracket, in the interior. When you floored it, it would send 12V to the kickdown solenoid, which would yank it down a gear or 2 depending on how fast the car was going. Quite simple and crude actually.
Old Feb 1, 2003 | 10:15 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
So it shouldnt have a 12 volt souce going to it as soon as ya turn the key?
Thanks for the help so far!!!
Kat
Old Feb 2, 2003 | 07:24 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The solenoid shouldn't, but the switch should. Its 12V supply should be switched ignition.
Old Feb 2, 2003 | 08:33 AM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Thanks alot dood!
Kat
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
Giocio
Oct 1, 2015 12:20 PM
tattmann
Sep 27, 2015 05:20 PM
luvofjah
Sep 3, 2015 07:08 PM
