Bad torque converter????help please
Subscribe
Feb 2, 2003 | 11:38 AM
Ok here is my problem about 2 weeks ago my car lost almost all power and would hardly run this lasted for a few minuts then ran fine no SES codes were set.last night night it happened again but it is still doing it(no SES codes set) the sar bucks and shakes almost as if it was a manual and i tried to takeoff in 3ed gear or something its worse in gear but still running rough in park and neutral could this be my torque converter went out ???
89 Formula with a 350 TPI and 700R4
plug wires look good timing is good help please??
Reply 0
Feb 2, 2003 | 11:54 AM
Does your ses light work when the key is on but the engine is not running?could also be bad gas(Ive had this problem before,same symptoms)maybe the torqe conv. is not dissengaging(sp?).
Reply 0
Feb 2, 2003 | 12:54 PM
my problem seems to be the passenger side of my engine not getting fuel. when i pull those 4 wires it runs the same and i am getting spark. plugs are clean and dry and i am getting fuel to the rail . i dont think the 4 injectors are firing for some reason.
any help please
Reply 0
Feb 2, 2003 | 01:14 PM
that sounds like the wiring.check it out.use a test light or a meter(if u got 1)
Reply 0
Feb 3, 2003 | 02:57 PM
Yep, I had a loose wire got it fixed thanks
Reply 0
Subscribe
