305 to 350 flywheel 2x check
Old Feb 2, 2003 | 11:54 AM
swerve-driver's Avatar
From: "When the going gets weird, the weird turn pro." -RIPHST
Car: 1991 RS
Engine: 383TBI Fastburns and 2"TB
Transmission: T56 held up by Spohnstuff
Am swapping a 305 to 350 and wanted to be sure I can use my stock 305 flywheel with the manula T5.
Stock motor/trans 1991 305 / 1991 T5.
New setup: 1993 350 / 1991 T5
SEARCH RESULTS
After searching/reading this site I gather this:
The 305 flywheel can be used with the new 350 motor, as long as both engines have the same rear seal. Can anyone confirm?
Then, I saw that GM lists 2 part numbers for flywheels:
Vin E: 14088650
Vin F: 14088646
The 14088646 is said to be a "lightweight" flywheel ("Dewey" post). I am wondering if there is a meaningful difference between the two.
Would they use the "lightweight" flywheel on a 350 to reduce rotating mass with the idea that the 350 can make enough torque to overcome the reduced intertia of the lighter flywheel?
Main reason for this post is to double check with any veterans out there to be sure that I can use my 305 flywheel with the new 350 motor and not have balancing problems.
Any help/clarification is appreciated-
S-D
Old Feb 2, 2003 | 11:59 AM
ontogenesis's Avatar
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
i can only speak positively for auto's, but EVERYTHING i've ever seen on a 305 will work on a 350
Old Feb 2, 2003 | 12:11 PM
ctandc's Avatar
In short YES you can.
The difference is the 1 piece rear main seal, and BOTH your engines are 87 later so you're okay.
The lighter flywheel was used on performance applications for a lighter rotating mass. As you know, no 350 had a 5 speed behind it from the factory.
So bolt 'em on go.
As for auto's, there IS a difference when you swap from or to a 86 and earlier engine ( 305 OR 350 ) they were "zero" balanced, and the 87 later were NOT.
The flexplate ( auto ) would have weights on it 87 Later, and the flywheel ( manual tranny ) would have holes drilled 87 later, earlier units would not.
HTH
Old Feb 2, 2003 | 04:28 PM
Car: 1991 RS
Onto and ctandc-
Thanks for your help- I can always learn something here.
Am getting ready to paint my engine bay- engine will go in soon and this is one more question out of the way.
Thanks again-
S-D
Bubbajones_ya
Jul 6, 2024 08:32 PM
sheachopper
Jul 31, 2019 11:27 AM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
mfp189
Sep 27, 2015 09:25 AM
