Clutch chatter...grrrrr
Old Feb 4, 2003 | 01:26 AM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
Argh.....so I just put this T5 in my car about 45 days ago. It was running fine until about 5 days ago. Now I can't launch the car in 1st gear on a flat or inclined street without the clutch chattering/grabbing EVERY FRICKIN TIME. And I've tried EVERY launching method so I think something is wrong with my clutch. Anybody have experience with LUK clutches??? Good or bad??? Also, all the clutch components are new except the flywheel which was resurfaced. What do you guys think???
Old Feb 4, 2003 | 08:09 AM
LG4TA's Avatar
Car: 83 T/A WS-6
Engine: LG4 305
Transmission: T-5 Manual Clutch
Axle/Gears: 3.73 Positraction
Clutch chatter
I am guessing that it could be debris on the clutch surface such as oil or antifreeze. Most of the time oil will do that. If everything was new I would not know other than that.
Old Feb 4, 2003 | 10:23 AM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
your flywheel may have been re-surfaced so many times that you need to shim it..............very typical with hydrualic clutches
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
Night rider327
Sep 2, 2015 04:18 AM
