T-5 rebuild
Old Feb 4, 2003 | 02:24 AM
tony1784's Avatar
Car: 85 Trans Am
Engine: SBC
Transmission: TH400
Axle/Gears: Moser/Strange 9"
T-5 rebuild
I have a borg warner T-5 in my 85 trans am. I am building a 383 that the shop said will put out at least 450 horsepower and 500 lbs of torque. my question is what should i do to my trans so it will handle the power? the syncros for 1st and 2nd gear are bad already so its time to be rebuilt
Old Feb 4, 2003 | 05:40 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Drive it gently, avoid big clutch dumps and speed shifting.
A rebuild is a rebuild, not a whole lot you can do. There's no way to make the shafts or gears any bigger, or the case stronger, or do anything else that really makes a huge difference to the ultimate strength of the trans. It's never going to be a 4-speed.
Old Feb 4, 2003 | 07:43 AM
Fevre's Avatar
Car: 89 Formula
Engine: 355
And avoid sticky tires. Burnouts with not so sticky tires is easier on the tranny then powershifting with sticky tires.
Old Mar 26, 2003 | 11:25 AM
daturbosix's Avatar
Car: '92 Firebird
Engine: Poncho 455
Transmission: TH400
Axle/Gears: 12bolt
yeah dude, stop doing the burnouts, that might let you use the trans a bit longer. and if it should happen to BLOW UP then buy a tremmic t-5!
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
hartsmike
Oct 2, 2015 07:11 AM
Derrick86
Oct 1, 2015 05:12 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
3.8TransAM
Sep 27, 2015 08:37 PM
