Posi messing up..
Old Feb 8, 2003 | 07:15 AM
STIFFLER's Avatar
Posi messing up..
OK I bought a new posi unti about a year ago and now all I am getting is LEFT wheel peel... what gives.. I am thinking about putting synthetic in with the gm additive maybe 2 bottles of that stuff what do you guys think..??
Old Feb 8, 2003 | 11:13 AM
ede's Avatar
ede
i ithnk you should of put oil and additive in when you did the install. most likely neither will cure your problem.
Old Feb 8, 2003 | 02:38 PM
MdFormula350's Avatar
well if you used the recommended gear lube and gm posi additive the first, then something must of screwed up, i guess your going to have to see by poping off that cover and looking inside..
what post unit did you get?
Old Feb 8, 2003 | 02:41 PM
STIFFLER's Avatar
I did add everything it called for in the first place when I installed it.. fricken crap!! It's a Auburn posi unit.. just SHlT!!
F-body-fan
Jan 12, 2023 01:49 PM
KO1
16
Oct 15, 2015 05:00 PM
