What do I need?
Old Feb 9, 2003 | 07:31 PM
25THRSS's Avatar
What do I need?
What do i need to be able to shift into OD at WOT?
Old Feb 9, 2003 | 07:58 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
You need to remove the Throttle plunger sleeve and block the "detent downshift" passage. How to do this can be found here:
http://w1.601.telia.com/~u60113744/t...tranny_wot.htm
Just remember that after you do this, any speed above around 55 MPH will require you to manualy downshift into third if you need it to downshift.
Old Feb 9, 2003 | 08:02 PM
25THRSS's Avatar
Isnt there some type of corvette part or something B&M makes to allow me to do that? Also, what other effects on daily driving will plugging those holes have? Thanks
Old Feb 9, 2003 | 08:07 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
GM had the "B Car Fix" that was supposed to allow OD at WOT for police cars, which was a revised 3-4 shift valvetrain. Availability may be getting scarce on those. As far as the B&M upshift sleeve, all it is, is a billet sleeve made with this passage already blocked off.
Old Feb 9, 2003 | 08:18 PM
25THRSS's Avatar
Thanks for the info, i really appreciate it
