Shifting too soon....
Old Feb 10, 2003 | 08:51 PM
justadba's Avatar
Car: 88 IROC convertible, 88 Sport Convertible---both RED
Engine: 350 TPI in the IROC, 305 TBI in the Sport
Transmission: 700R4 in both
Had to replace my rear end gears....went from 3.23 to 3.73...also put on headers at the same time. On way to the muffler shop to weld that little missing piece to the Y pipe, my transmission went out.
Got a rebuilt 700r4...
My problem or dilemma....
From a stop, a little brake, lots of gas and let it go....pedal to the floor.
transmission shifts at 3500rpm 2nd to 3rd....can't tell for sure when 1st to 2nd happens since both wheels are spinning and so much other stuff is going on....
Should the trans be shifting that soon? or is there some adjustment needs done....????
Old Feb 10, 2003 | 09:53 PM
curt86iroc's Avatar
Car: 1990 IROC
Transmission: TH700-R4
the trans thinks you still have 3.23's out back. its not like a trans with a vacuum modulator, the WOT shift are controlled by the govoner. you have to adjust the gov. to set your shift points.
Old Feb 10, 2003 | 09:59 PM
justadba's Avatar
ok how do i go about that or do i need to get the trans shop to do it....
need to take it back to them as it is slow dripping fluid....been doing so ver 2 weeks
Old Feb 10, 2003 | 10:10 PM
curt86iroc's Avatar
Car: 1990 IROC
if your going back there anyway you might as well have them do it. or if you want to do it yourself, you'll need a govoner recalibration kit. you can buy one through summi or jegs. B&M makes one that im aware of.....
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
racereese
Oct 3, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
AmpleUnicorn88
Sep 24, 2015 09:15 AM
