Rebuilding rear-end, a little guidance please
Car: 91 RS
Engine: 350 TBI
What I've got so far. . .
SLP posi
3.23 gears
What I'm about to buy. . .
Ratech's Complete kit (p/n RAT-308TK) from summit for $93. Hopefully this is what I need.
What I'm still confused about. . .
What rear diff fluid do I need? I was going to go w/ Mobil 1, but do I need to get some kind of slip additive or something like that?
I still need speedo gears, but I got a tranny guy who's going to help with that later.
Am I missing anything guys?
Thanks,
-The Gunny
SLP posi
3.23 gears
Thanks,
-The Gunny
Car: 4
Engine: 6
Transmission: 5
That's mostly about it.
You might want to get a "crush sleeve eliminator", so you can tighten the pinion nut as tight as you want, and not have to stop when preload is reached; and some axle bearings & seals, since then every wear part in your rear will be new.
If you're in Oceanside, I've used Oceanside Driveline before for other stuff, they seem to do good work.
3.8TransAM
Sep 27, 2015 08:37 PM
