Posi's
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
Posi's
does anyone make a cheap, posi unit for 26 spline axles out of a camaro.
Transmission: 4L80E/4L80E
Non-take-off posi carriers and conversion products like PowerTrax run about the same - ~$350. If you're happy with your current gear ratio, you can install the PowerTrax yourself. If you want to change your gear ratio at the same time, go with an aftermarket posi carrier (available in 26-spline version) or the above-mentioned SLP take-off - but, you're looking at set-up labor which will add to the cost.
Most likely, the cheapest setup you'll find is getting an entire rear axle that already has a posi and the gear ratio you want in it.
KO1
16
Oct 15, 2015 05:00 PM
