will any chevy v8 tranny fit?
Car: 85 Trans Am WS6
Engine: 305HO L69
My car is an 87 Camaro LT with the LG4 and 700R4. I'm putting in a carbed 350 from a 74 vette. I'm also going to convert to a manual transmission. My question is basically what's in the title. Will any transmission that was originally matched to a chevy v8 fit to my engine in my car, are there certain trannies i have to choose from that will fit my engine, or certain trannies that fit my car? Also, if I do go with a tranny from a different car, what parts need to match the tranny and which need to match my car (i.e. bellhousing, pedal assembly, etc.)?
Car: 91 Camaro RS
Most of what I have to say will start with "as far as I know", but here goes
V8 trannies should have the same block-to-bellhousing bolt patterns, except LS1's. I don't know about big block trannies, but I've never heard about a difference. The block from a 74 Vette should have a 2-piece rear main seal, so you will need a flywheel for that application, or an adapter so you can use a flywheel made for a singe piece rear seal. Check Summit or Jegs for that, I forgot who makes it.
Clutch pedals depend on what kind of clutch linkage you are using. I have hydraulic pedals from an 89, and I use them for the hydraulics for my 97 T56. I believe that the tranny will dictate whether you need a mechanical or a hydraulic clutch linkage. Different trannies need different types of linkage too. For instance, the thirdgen T5's all use a standard clutch setup, but the 4th gen T56's (maybe t5's too) use a reversed setup, so the fork pulls rather than pushes.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
All Chev V8's have the same bellhousing bolt pattern. BBC and SBC are the same.
The trouble with installing a manual transmission in a third gen is that there's no room beside the tranny for the clutch lever. That's why third gen bellhousings have the clutch lever/slave cylinder at a 45* angle. If it was straight off the side of the bellhousing, it would be about where the gas pedel is inside the car.
Engine: 305HO L69
i'm pretty sure i want the borg warner t10 4 speed tranny. is this tranny the same for all chevy's, or is there a difference between the ones that came in camaros and novas and vettes, etc.?
Car: 4
Engine: 6
Transmission: 5
Yes the ones for 82 Camaros (the only one they came stock in) are different. They are designed to be bolted in at an angle, rotated clockwise about 20°, so that the clutch fork will clear the floor pan as Stephen mentioned above. As a result, the trans mount pad has to be rotated too. And of course, there has to be a torque arm mount on it in order for it to work in these cars.
Internally the T-10 for one of these is no different, but no other one will bolt in.
The clutch linkage does not care what kind of trans you have, up to the T-56 which is different. All the others will work with either the hydraulic system (which I personally prefer greatly) or the older inferior mechanical linkage system, with all of its friction and other problems.
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
amargari
Nov 10, 2015 02:09 PM
[GA] Shorty headers
Night rider327
Sep 16, 2015 02:20 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
