hydraulic clutch ?????
Old Feb 23, 2003 | 08:02 PM
1986redbird's Avatar
I have a quick question, how do you remove the hydraulic lines for the clutch from the master cylinder and the slave cylinder ??
there are no nut or clamps, it looks like the lines go straight into the cylinders. it looks like there is a set-screw or something near the hole for the lines. is that it.
Old Feb 23, 2003 | 09:35 PM
forever3's Avatar
Car: 88 IROC
Engine: 5.7 L98 TPI
Transmission: 700 R4
I see in your sig both of your cars are automatic.. what are you working on? Internal or external slave cylinder?
Old Feb 24, 2003 | 05:58 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
There's a roll pin.... you drive it out, and the line has a fitting on the end of it with a little groove that the pin goes through to retain it.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
Night rider327
Sep 2, 2015 04:18 AM
