advice please?
Old Feb 28, 2003 | 10:58 PM
GTA's Avatar
GTA
Car: 1992 GTA
Engine: running
Transmission: working
Axle/Gears: both
advice please?
Hi,
I could use some advice please,
I have a 700-r4 that is all rebuilt with great parts and a transgo shift kit and all the bell and whistles BUT i have a small problem
WERE should the ttc clutch lock (speed) I have some custom burnt proms and can't decide were to lock the converter, when the ttc clutch locks it bogs the car (early or late) I want a good ttc lock speed and dont' want to hurt the trans converter in the process (earlier = hard on clutch components in converter_ later= hard on trans b/c it = more heat oh th eng is a 5.7 and the stall is 2100 opinions please? thanks (ps the converter was built in house and is not a "name " brand though it is of good quality.
Old Mar 1, 2003 | 12:28 AM
kevinc's Avatar
Car: 1982 Z28
It depends a lot on what rear gearing you have. The TCC lockup logic evaluates VSS input.
Back when I had 3.42 gears and a Vigilante 2800rpm stall TC, I liked 50mph for lockup and 35mph for unlock. Lower than 50mph lock and it would bog the engine.
Old Mar 1, 2003 | 11:26 AM
GTA's Avatar
GTA
Car: 1992 GTA
Engine: running
Axle/Gears: both
Thanks, Any one else??
Old Mar 1, 2003 | 01:03 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
If you have the ability to burn your own PROMs, then you just need to experiment. I leave mine at the stock setting of around 40MPH. My personal feelings is that I wouldn't go past 45-46 MPH.
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
gord327
Sep 29, 2015 10:18 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
mrdevontay
Sep 2, 2015 08:04 PM
