auto. shifting...
Old Mar 6, 2003 | 08:48 AM
CamaroRS385hp's Avatar
Car: 1987 Iroc-Z28
Transmission: auto
auto. shifting...
I have a '92 v-6 automatic. i usually drive w/ it in drive, and if i'm the highway then in overdrive. i like racin people from stoplight to stoplight, and i usually just have it in drive for that. will i get better acceleration if i switch to 1, then 2, then D then OD manually? also, if i'll get better acceleration by "shifting" on my own, should i shift at the redline? and if not, where...thanks
Old Mar 6, 2003 | 12:34 PM
MdFormula350's Avatar
i think leaving in it drive works best for me, manually shifting i hardly do.
but manually shifting i would shift at like 4,500 everygear in my car.
my car seems to run a tad faster leaving it in drive...
i always run my car in overdrive unless i am about to race...
Old Mar 6, 2003 | 06:13 PM
Breadfan's Avatar
700r4 transmissions have extra holding members when manualy shifted , make the trans stronger . I found out the hard way that dropping from 4th straight to 2nd , and hammering blows the one way clutch apart . If you go to 3rd then 2nd less likly to do damage . because 3rd and 2nd use some of the same holding members .
Old Mar 6, 2003 | 07:22 PM
Car: 1987 Iroc-Z28
Transmission: auto
you run in overdrive unless you're about to race.....so you do manually switch gears when you're racing? or race in drive?
Old Mar 6, 2003 | 10:04 PM
TransAmTBI's Avatar
Engine: 305 TBI
Transmission: th700R4
I always shift manually weith my auto... one it gives me a little sence of driving stick..makes me feel better about myself.. 2 my car seems to have much more tork in 1st and 2nd gears.. plus when racing you never take it out of drive for overdrive unless you racing a straight 2 mile straightaway and you redline in drive
Old Mar 6, 2003 | 11:29 PM
well at the track i like to do both ways.. but drive seems to work best for me..
on the street just crusing i run in od all the time..
when street racing i throw it in drive and run like that.
when street racing you dont really have time to sit there and warm up the tires, so i leave it in drive so i can hook up better, because anywhere in first gear i spin the tires at wot.
Billgluckman
Members Camaros
36
Nov 24, 2015 07:29 PM
armybyrd
Sep 26, 2015 03:37 PM
James Sutton
Sep 23, 2015 01:56 PM
rsrookie
Sep 5, 2015 07:08 PM
watajob
Jan 3, 2001 03:56 PM
