9 bolt slipen
Old Mar 7, 2003 | 07:15 PM
c4boom's Avatar
Car: 87 iroc and 88 k2500 tbi truck
Engine: l98 and lo5
Transmission: 700 r4's babby
9 bolt slipen
is there a way to tighten up the posie. it is still to loos for my likes even with low miles on it and a easy life befor i got it. kid that had the rear befor me was a wimp always talked about how he got 50,000 out of a set of tires. then wrecked the car slid off the road in the snow and smoosh
Old Mar 7, 2003 | 09:47 PM
ede's Avatar
ede
what exactly are you wanting to tighten up? back lash, clutches?
Old Mar 8, 2003 | 09:18 AM
c4boom's Avatar
Engine: l98 and lo5
the clutches i would like it if the thing would hold a bit more hear up in NH i have to move it some times in the winter so i can get to the back of my shop but as soon as one tire hits the ice i am usually stuck it passes the wheel torque test just wondering if there are tighter clutches or some thing that i could put in it to give it a more positive lock
Old Mar 8, 2003 | 01:08 PM
ede's Avatar
ede
don't believe you can adjust anything to make the clutches work better. odes it have gm posi additive in it? if not or don't know change the oil and add some, gm only. you can replace te clutches and springs, which would help a lot if the originals are worn and weak.
Old Mar 8, 2003 | 01:17 PM
c4boom's Avatar
Engine: l98 and lo5
thanks i was hoping there was a hi friction cone or heavy duty springs or some thing so come spring i will pbly rebuild it.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Numbah-1
Sep 12, 2015 08:57 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
