12 bolt rearends??!!!
Old Mar 9, 2003 | 07:47 AM
Pat Westerkamp's Avatar
I remember some were I believe here seeing some links to places that do 12 bolt setups for 3rd Gen does anyone know of some sites or places that i can peek at some.
Thanks Pat
Old Mar 9, 2003 | 08:59 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Moser, KTRE
Old Mar 9, 2003 | 09:02 AM
Z_Ghost's Avatar
http://www.moserengineering.com/mose...s.asp?CatID=28
Go down to were it says "12 Bolt - F-Body and Coil Spring Rear"
Old Mar 9, 2003 | 09:05 AM
NJITIROC's Avatar
Car: 1989 IROC-Z
i second the moser, but read this before you buy from ktre:
http://www.fbody.com/ktrewarning.htm
Old Mar 9, 2003 | 02:10 PM
drain89's Avatar
Car: 02 WS6 White/Ebony
Axle/Gears: Stock 3.42
If spending that kind of money, have you thought about buying a Moser nine inch rear? It's not made by ford so you wouldn't be blaspheming your car. Stronger. Period! And gear changes are soooooooooooo much more simpler than the gm designed rears.
Old Mar 9, 2003 | 05:13 PM
ede's Avatar
ede
strange and currie also make 12 bolts for thirdgen f bodys
Old Mar 9, 2003 | 06:53 PM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
the 9" rear is only slightly stronger than the 12 bolt is, and only if its setup right. plus the 12 bolt is much more efficient than the 9" due to the much smaller pinion offset....the difference is as much as 5% more loss with a 9". and who changes gears like that anyways? unless your a race team and your worried about changing them if they break. 99.999% of people are never going to change the gears in an aftermarket rear anyways, cause you order them with the ratio you want.
and the 9" from moser would have cost me almost 2900 bucks i think, as opposed to the 12 bolt which i paid 2313 for. The prices you see on the website dont include everything, start adding options and 9" gets expensive quick.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Numbah-1
Sep 12, 2015 08:57 PM
WickedBowtie
Sep 11, 2015 11:24 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
