I messed up my tranny tonight!
Old Mar 10, 2003 | 10:46 PM
Big454blockchevy's Avatar
Car: 86 z28
Engine: Hyd. roller 498
Axle/Gears: 12 bolt 3.90 gears
I can't figure what happened , I was kind of tired and this mustang gt kept at me until I went for it. No problem with him , I kind of knew I was going to smack him down but I still went for it. Ok after I slowed down and high beamed to show it was over , he kept reving his engine, so this is where I don't know if I went into reverse or maybe downshifted, I just remember reving my enigne and the engine acting as if it was in neutral so that is when I started messing with the shifter and bang I started hopping all over the road. I went home real slow. When I get home I take a look underneath the car and I see that the trans cover broke , the bolts are still attached to the engne block just the cover seperated(broke) . It broke enough that while the car is on ramps the starter will not engage the flexplate.
Old Mar 11, 2003 | 05:58 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
When you say "cover, bolts still in engine" are you referring to the transmission bellhousing? If that is broken or cracked, then the tranny is done. Other than "used" you can't buy just a tranny case.
Old Mar 11, 2003 | 07:33 AM
Car: 86 z28
Yep, the bellhousing is cracked.
F-body-fan
Jan 12, 2023 01:49 PM
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
bjpotter
Oct 4, 2015 07:48 PM
