Does the trans pump make noise when bad?
Old Mar 11, 2003 | 01:48 PM
86 sports coupe's Avatar
Car: 86 sports coupe-83 berlinetta
Engine: 5.0 in the sports coupe-350 in the berlinetta
Transmission: 700r4 in the sports coupe-turbo-350 with a 2500 stal in the berlinetta
My car has a turbo 350. When im at a light and the trans is in D
I hear a funny noise i believe is coming from the trainny.When i up the RPMs a couple hundred the noise goes away. the reason im asking about the pump is i had a bad vibration problem from the drv shaft and it caused the trainny to come looose from the engine.Also can a transmission make a car shake in drive at idle.Going down the road it seems ok.Could the shake come from my frankinstein engine?(Used rotating parts from different 350)The tach seems steady at idle. thanks.
Old Mar 11, 2003 | 03:30 PM
jdrafke's Avatar
Same problem
Hey i got the same problem when im on the brake i hear the noise, and when im in reverse on the break its even worse. Help out guys :hail:
theshackle
Sep 17, 2020 08:26 AM
B_Dubya
Aug 26, 2015 05:09 PM
beachrodder
Aug 25, 2015 08:05 AM
mizz0313
Aug 12, 2015 06:45 AM
BlackBoulder
Aug 11, 2015 11:15 PM
