91 10 Bolt?
91 10 Bolt?
I am trying to get a mini spool for a 91 z-28 with disc brakes and as far as i know a stock rear end. My question is where can i get one, what size is my ring gear diamater, and do I have 26 or 28 spline axles? I know that some people don't suggest a mini spool for the street but i'm gonna try it for now. Thanks.
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Unless I'm out to lunch, doesn't the spool just fit into your open differential? If I'm right, you don't need to switch the carrier out.
Ed
Ed
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
A full spool does but nobody makes a full spool for a 7.5" diff. They do make mini spools though.
Car: 91 Z/28
Engine: 6.3 L98
Transmission: TH350 4500 STALL
Axle/Gears: 3.73s
Correct..For some reason no body makes a minispool for a 7.5 with 28 spline axles..but they do for 26 spline?Why this is..Got me......
Numbah-1
Sep 12, 2015 08:57 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
