Dana Pro-Built
Old Mar 16, 2003 | 04:29 PM
DTL504's Avatar
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
Dana Pro-Built
Im having problems with my street/strip tranny. It leaking fluid from what I can see its coming from inside the bellhousing. It only leaks while the engine is running. The worst part is that im
losing all my probuilt race fluid. I know that its not coming from the TV cable or dipstick. Im in he process of breaking in my engine and trying to keep it above 2000 rpm but had to shut it down because of the leak . Any suggestion will be greatly appreciated.
I will try to call you tomorrow if I cant get it work out tonight.
David
Old Mar 16, 2003 | 05:07 PM
DTL504's Avatar
Disregard Dana I think I have found the problem, atleast I know where im getting this big puddle from. The tranny line has a pin hole and it was shooting out only when the engine was running. I guess that what happen after the car has been sitting for so long and install all new parts then little things cant seem to handle the new stuff. However I have lose about a quart and half of your Probuilt Special Fluid that you send with the transmission, Can I buy two quarts.
David
Old Mar 17, 2003 | 02:08 PM
Pro Built Automatics's Avatar
I will e-mail you about getting some fluid.
sailtexas186548
Jan 19, 2016 12:21 PM
Americanmouse
Sep 7, 2015 12:10 PM
Chevy3shitty
Sep 1, 2015 09:22 AM
sailtexas186548
Brakes
Aug 13, 2015 11:47 AM
MENINBLK
Aug 5, 2015 11:58 PM
