Need Help Quick-Tranny Swap
Old Mar 17, 2003 | 02:10 PM
StevenK's Avatar
Car: 91 Z28
Axle/Gears: 3.73 Hawks 8.8
Hey guys I am doing the Auto -> t5 swap on my 91 Z28 (350) and I got it almost complete. I read in the tech article that the reverse switch light wires were just taped under the dash but as far as I see this is incorrect. It looks from my repair manual that it is actually one of the wires that comes off of the automatic shifter connector/wire harness. Do any of you guys know which wire it is (either which position in the harness or color of wire) that I need to splice into to get the reverse lights to work when I put the tranny in gear? Any help on how to find the reverse wire would be greatly apriciated so I can drive the car home. Thanks in advance, Steven.
Old Mar 17, 2003 | 02:53 PM
Schultzy89GTA's Avatar
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
Steven,
I don't know it off the top of my head but I will check back when I get home tonight and if you have not received and answer I can help you.
Good luck. These cars are a blast to drive with the manual. Fun factor went way up for me.
-Schultzy
Old Mar 17, 2003 | 08:16 PM
Car: 1989 GTA
The reverse light wires should be dark blue and light green.
Good luck!
-Schultzy
Old Mar 18, 2003 | 01:31 PM
StevenK's Avatar
Car: 91 Z28
Good luck!
-Schultzy
you were right, awesome, thanks man, drove it home and its a whole new car. Now all I have to do is figure out how to change the PROM so its a little less punchy at low RPM.
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
jharrison5
Aug 19, 2015 05:53 PM
355sbcTPI
Aug 19, 2015 04:38 PM
