Thirdgen Disc Brake Rear End or Fourth Gen?
Old Mar 18, 2003 | 07:43 AM
CustomCarShop's Avatar
Which is better 3rd or 4th Gen? I can get both for the same price. Just wondering if there is a difference other then on the 4th gen the wheels stick out 2" more.
Old Mar 18, 2003 | 01:53 PM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
i think its a bigger brake as well, but i think its still a one piston caliper
Old Mar 18, 2003 | 05:32 PM
Which one is better though?
Old Mar 19, 2003 | 09:05 AM
91 Camaro Z28's Avatar
4th gen rear end is better if you plan on using 4th gen wheels- otherwise you'll have to get spacers since the 4th gen rear is a different size than the 3rd gen. Both should bolt up with a little tweaking- i'd go 4th gen just because its newer and has newer technology
Old Mar 19, 2003 | 09:47 AM
Spacers?
I heard that witht he 4th gen rear end, the stock IROC-Z wheels will stick out 2".
Spacers are used to make them sick out more? I went to my car & measured, 2" past where my wheels are now, myt wheels willbe sticking out around a 1/4" past the fenders...
Old Mar 19, 2003 | 09:58 AM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
id say the 4th gen is better all around, better breaking performance, its newer, and the gears and rear itself should be stronger and if you keep your stock wheels itll give the rear a more aggressive look with the 4 inch longer track, definately go 4th gen, if you have a choice theres no reason to go third unless its a firehawk dana rear.
Old Mar 19, 2003 | 10:25 AM
thanks man..
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
sailtexas186548
Jan 19, 2016 12:21 PM
novaderrik
Aug 10, 2015 12:44 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
