9-bolt gear ratio
Old Mar 20, 2003 | 06:33 AM
cdogc350's Avatar
9-bolt gear ratio
i got these #'s off the ring gear of my 9-bolt:
0575 029001
BW LT2 77A
....Can anyone tell me what gear ratio it has.
thanks...
Old Mar 20, 2003 | 08:16 AM
ede's Avatar
ede
WAG but i'd bet the ratio is stamped on it, something like 13:43, or you can count teeth and do the math
Old Mar 21, 2003 | 11:17 PM
cdogc350's Avatar
i checked to see if the ratio was on it but all i got was these #'s...i cleaned it well to see if the grease could be hiding it...where could i run these #s to find it out?
Old Mar 22, 2003 | 07:38 PM
Steve86TA's Avatar
Car: To many to list
count the gears on the ring gear and the pinion gear.Then divided the 2 numbers
Old Mar 24, 2003 | 05:30 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
2.77
Miles
Old Mar 24, 2003 | 05:51 PM
Momar's Avatar
Yup, I know mine were stamped on the ring gear. The numbers you gave have 2 and then a space and then a 77 so I would guess 2.77 since that is a possible and probably the most common gear ratio that would make since. Oh, and also Miles knows his 9 bolts.
Ben
Old Mar 25, 2003 | 07:25 PM
cdogc350's Avatar
DAMN.......2.77...thats horrible..
no-wonder my car isnt pulling as it should....its got a nasty thumper in it. it should be blasting right now.
well...now i know what my missing link is, thanx
Hotrodboba400
Dec 10, 2019 07:07 PM
88rscamar0
Sep 23, 2015 09:08 PM
dbrochard
Sep 19, 2015 08:13 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
