Shifter recommendation...
Car: 1991 Camaro RS
Engine: L03 305 V-8 (for now ;) )
Transmission: T-5 5 speed
Axle/Gears: stock... whatever that means :)
Hey. If you follow the boards at all you know im in the process of rebuilding a T5.
I want to replace the shifter and Im kind of torn between the Hurst (if they even make one, I dont know), the B&M Ripper, or the Pro 5-0. I dont think I want to spend the money on the Pro 5-0 yet because I plan on getting a Tremec TKO ot TKO-II when I start making modifications.
So...what do you all think I should do? Is the B&M a good choice? Thats honestly the one Im leaning towards.
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
Any of those would be a nice improvement over stock.
Since you are looking for recommendations, how long before you swap tranny's? I would put that money towards the new tranny and shifter rather than a shifter that will be unusable in 'x' amount of time.
.02 for free!
-Schultzy
.02 for free!
-Schultzy
Car: 1991 Camaro RS
It may be a year before I swap trannies. I will be buying "other" stuff before I get to the "I need a Tremec now" stage...
