Vibration questions
Old Mar 21, 2003 | 12:59 PM
Firebird90V6's Avatar
Vibration questions
Alright folks. Not a thirdgen specific question but fbody none the less. I have a1995TA that i blew the tranny mount on. I replaced with a Energy suspesnion mount that was recalled cause it caused vibration. So i replaced it with a Prothane mount that seemed to quell the really bad vibration that the Energy suspsension mount caused. But I my new question is i still feel a little stiffer vibration under super hard ecceleration. The new mount is installed correctly and isnt loose. Im being told by a few people that a little stiffer vibration is normal with the poly mounts cause they are stiffer then the oem ones. Im also being told that i could have something else wrong mount wise. Its not the motor mounts im almost 100 percent sure of that. is it possible when i dusted the tranny mount i tore the torque arm or something else. The Vibration isnt terrible its just a little more then stock. Thanks for the help guys. Also my 85 TA is i think rounding its last legs before it needs some serious suspension and tune up work. Thanks again guys.
Old Mar 22, 2003 | 02:06 PM
MdFormula350's Avatar
i fell anything other than the soft rubber stock mounts you will feel a tad more vibration but the strength is worth i think...
Americanmouse
Sep 7, 2015 12:10 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
db057
Aug 22, 2015 08:17 PM
spaigo
Aug 21, 2015 07:46 PM
redmaroz
Aug 16, 2015 11:40 PM
