converter lockup
Old Mar 24, 2003 | 07:03 PM
TheViper's Avatar
Car: '84 Z28
Transmission: th2004r
converter lockup
i'm probably going to get a tci lockup wiring kit for my th200-4r.
when does the convertor lock up? i know it locks up when your cruising in 4th but how much gas do you have to give it to get it to disengage? do you have to get it to kick down to 3rd? also, does it lock up in any other gears besides 4th?
Old Mar 24, 2003 | 10:01 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If you wire the TCI kit according to its instructions, it will lock the transmission when cruising in 4th. It also has a vacuum switch that will unlock the transmission at about 8" of vacuum or so, but it's adjustable. If you have a loose converter the vacuum switch can cause some annoying cycling sometimes.
loud91rs
Camaros Wanted
Mar 28, 2016 04:13 PM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
bjpotter
Oct 4, 2015 07:48 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
