t-5 swap
Old Mar 28, 2003 | 08:12 AM
tstokka's Avatar
Car: 2- 1986 TA 1 t-top 1 hardtop
Engine: 305s
Transmission: autos
t-5 swap
Is the only thing different with the v-6 t-5 and the v-8 t-5 the bell housing?
Old Mar 28, 2003 | 09:33 AM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
The difference isn't in the bell housing. A V6 T5 has a 14 spline input shaft, and a V8 trans has a 26 spline input shaft. Also V6 tranny's had lower gear ratios than the V8 tans.
You can get a special 14 spline clutch disk that allows you to use the V6 trans behind a V8, but if you are going to buy a trans for your car, try to get a V8 version and save yourself the cost of buying a new clutch disk.
midge54
Sep 2, 2015 06:27 PM
Cacike
Aug 27, 2015 05:10 PM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
