700 to 350 & torque converter questions
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
ok, before i even get started, i searched all over. I can't find the info i'm lookin for anywhere and i can't find a 200c driveshaft...so from center of u joint to center of u joint, how much shorter does my stock 700r4 driveshaft need to be to swap in a th350?
secondly, how do i identify what stahl speed my torque converter stahls at? i know it's a b&m, but i don't know what model i have or what stahl it is...
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
if the Th350 is a 6 inch tail, it needs to be LONGER (the driveshaft)
if the TH350 is a 9 inch tail you can use your 700R4 drive shaft
do a stall test, wont be very accurate, but it will give you an idea
