Manual TC lock up switch ?
Old Apr 13, 2003 | 09:11 PM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
Yeah Yeah I am sure u got lots of these, I did the search but really wasn't satisified with what I found and I can only go thru so many pages on dial-up, lol. Anyways heres the questions.
On the wiring. Do I need a ground on my switch and if so, then I just use the one wire going from my switch to a ground and the other wire to connect both the A&F on my ALDL? Or is it just one wire to the A and the other wire to the F?
Other question, I have a B&M 28,000 GVW cooler, transgo shift kit and polly. tran mount. Is this manual lock up gonna hurt my tranny? It has 117,000 miles on it. And I assume I only flip the switch in the "on" position when I am about to race correct? Thank you.
Old Apr 13, 2003 | 11:10 PM
CAMAROsc350's Avatar
You just hook up one wire to the A and the other to the F terminal, A is the ground. As for it being hard on the tranny yes it is hard on it, The only reason i have one is i have no comp and i need it on the highway. If you do use it for racing dont make it a habbit. It only helps a very small amount anyway, to me its not worth the damage it could cause. hope this helps.
Old Apr 14, 2003 | 10:27 AM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
Yeah, I plan on only using it when I go to the track only. I later read that it is hard on ur tranny and TC but so is racing itself. Thanks for the info.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
89GTAOz
May 16, 2020 09:31 AM
stalkier
Aug 21, 2015 01:54 AM
Dialed_In
Aug 20, 2015 01:45 PM
