Used t56
Old Apr 16, 2003 | 01:46 PM
formula350sd's Avatar
Car: 89 Formula
Engine: 383 vortec tpi
Transmission: t56 woot
Used t56
Ive been looking to do a t56 swap in my car and aparently the easiest way to go is complete 4th gen set up my question is 3rd gen resource sells the whole shot used out of a 4th gen car is taht a pretty straight foreward swap into a 89 formula 350 or am i gonna hit a brick wall somewhere??
Old Apr 16, 2003 | 03:02 PM
YenkoZ28's Avatar
Car: 1991 Z28
Engine: 305 TPI under 14 psi
Transmission: aftermarket T56
Axle/Gears: Moser 12 bolt 3.08 gears
The easiest way to go is the aftermarket T56. They are designed specifically to retrofit into 3rd gens.
Old Apr 17, 2003 | 11:38 AM
Car: 89 Formula
I understand that but that involves rounding up a bunch of parts i dont have like the clutch pedal assembly the master and slave cylinders a bellhousing and what not. The retrofit,if im not mistaken, also requiers a shortened driveshaft and torque arm all that seems like more trouble than its worth.
Besides isnt the 4th gen trans is the same lenght as my TH700?
Old Apr 17, 2003 | 11:44 AM
NJITIROC's Avatar
Car: 1989 IROC-Z
i obviously havent done both on my car. but from what i read, the 4th gen trans swap is more straight forward than the aftermarket. you just take everything from the 4th gen and bolt it onto the third gen. no shortening no altering, nothing, just need a new crossmember (www.spohn.net)
i did the 4th gen t56 swap in my car with a friend and we didnt really hit any brick walls at all! good luck.
Old Apr 17, 2003 | 12:00 PM
Car: 89 Formula
Thanks thats all i needed to know:lala: :lala:
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bigjay89gta
Oct 15, 2015 08:04 AM
meeklay812
Oct 1, 2015 03:46 PM
Vincent135
Sep 28, 2015 10:50 PM
