Installing Disc brake rear in 88 Formula
Old Apr 16, 2003 | 04:20 PM
dp formula's Avatar
I need help with installing my rear.I have a posi disc brake rear I want to install in my 88 formula.The rear is a 9 bolt out of an 85 trans am. I also have the the proportioning valve and master cylinder from the trans am.What parts do I need to make this work.Do I change the proportioning valve and the master cylinder? Do I also have to change the power booster? Thanks a lot!!!
Old Apr 16, 2003 | 04:25 PM
CASEY87GTATPI's Avatar
No it should be a complete plug and play opperation.
Old Apr 16, 2003 | 04:26 PM
let me know how it goes.
Old Apr 16, 2003 | 04:35 PM
dp formula's Avatar
Casey did you mean this is a direct bolt in ? There is no need to change the other parts?
Old Apr 16, 2003 | 05:12 PM
Yeah you should have no problem all the spring perches and panard bars are the same all you need to do is make sure the e-brake stuff is all good!
Old Apr 21, 2003 | 02:51 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
rear disc conversion
you WILL need to change the proportioning valve and master cylinder (the proportioning valve is set up different, and there is a check ball in the master cylinder). You might have some funny operation if you don't change these components from your drum brake 91 setup... i converted my '88 drum to a '84 disc system, changed all of those components, didn't have a problem.. you will also need new parking brake cables from the equilizer back... if you need any other info, i'd be glad to help....
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
sailtexas186548
Jan 19, 2016 12:21 PM
novaderrik
Aug 10, 2015 12:44 PM
