Trans. Temp. Gauge Question
Old Apr 17, 2003 | 09:01 AM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
Ok, I am getting a trans temp guage and I was looking at the suggested parts section and it suggested I get this part.
Trans Temp Gauge Manifold
Do I really need this or does it just help simplify the install? This is the gauge I am getting.
Trans Gauge
Old Apr 17, 2003 | 11:18 AM
ede's Avatar
ede
i'd use a tee with one NPT hole and 2 holes for flared lines, no compression fittings
Old Apr 17, 2003 | 12:40 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
I wouldn't go splicing into the stock hard lines with compression fittings either. Just asking for trouble that way. But, people do it and get away with it though.
My guage sender is in a T at the input of my tranny cooler. I used adapters to go from the 5/16 IF stock lines into -6AN lines, which then adapt to pipe for the in/out of the cooler.
The other solution would be to drop the tranny pan and have a fitting welded on to that and just get the temp there.
Old Apr 18, 2003 | 10:25 AM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
eric...this is a pic of mine i just put in lasy week.
i used one of the B&M drain plug kits...and instead of putting the actual plug into the drain plug, i used the temp sender for the trans temp gauge.
hopefully it does not leak...but i figured if the drain plug kit is good enough for a drain plug, it must be good enough for the sender...
keep it real man...
-brian
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
PestilenceIV
Aug 20, 2015 02:33 AM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
