Need some flywheel knowlege
Old Apr 19, 2003 | 08:09 PM
2.73's Suck's Avatar
Car: 1985 Mustang GT
Engine: hamsters
Transmission: a hamster wheel
I recently bought a T-5 with all the parts I need to make the switch from my has-been-slipping-for-2-years-but-still-works-somehow, 700r4. The problem is that the tranny and flywheel come from an 86 trans-am. If i get lucky it will be one of the few 86 one-piecers but if not what is the difference in the two-piecer? I read some where that the two-piecer flywheel is 12-something inches while the one-piecer is 14. Is this true and could I just use the smaller flywheel? Thanks in advance for help.
Old Apr 19, 2003 | 08:16 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That is not true. Both are 12¾" in diameter.
The difference is the bolt pattern where it bolts to the crank.
I'd take a pic but I'm too lazy to dig through my stock of flywheels and flex plates.
Old Apr 19, 2003 | 09:29 PM
Engine: hamsters
86 flywheel
Can I just use an 87 flywheel/plate/disc with the 86 tranny in case I do end up with the older style, which I will because I have terrible luck. I assume its yes but since I'm not sure I figured I should ask.
Old Apr 19, 2003 | 10:43 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
from what i understand all 86's got the one peice RMS............so the flywheel will work with an 87 motor
if you happened to somehow get a 2 piece RMS flywheel, no it will not work
Old Apr 20, 2003 | 09:21 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The flywheel has to match the crank. Period. If you have a late-style flywheel and an early-style crank, or vice-versa, it will not work. Period. It is possible to machine a late one into an early one, but not the other way around; on the other hand, it would be far more expensive to do that, than to get the right flywheel at the junkyard.
Clutches are the same. Neither the clutch, nor the trans, not the bell housing, care which bolt pattern is on the back of the crank.
Old Apr 20, 2003 | 12:45 PM
Engine: hamsters
Thanks for the help guys!:rockon:
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
el_muerte
Sep 16, 2015 12:01 AM
