Posi Install?
Old Apr 20, 2003 | 03:09 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Posi Install?
Hey guys...
I have an '83 Z28 with 3.73 gears (factory), 5 speed and a 350. My problem is that either my posi is dead or i never had one to begin with. Not entirely sure right now because the old owner kinda thrashed the car, so it could be either and i can't find my RPO sheet anywere.
Anyway, enough with my rambling.... If i don't have a posi in my axle, can i install one using the other existing parts (ie. ring and pinion) and if it there, but dead, can it be rebuilt or does it have to be replaced?
Thanks.
Old Apr 20, 2003 | 07:08 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
yes....
Old Apr 20, 2003 | 07:12 AM
ede's Avatar
ede
yes, only thing to watch is spline count on the axles, you should have 26 spline so the new carrier would need to be 26 or you'd need to swap axles for a 28 spline carrier.
Old Apr 20, 2003 | 09:59 PM
Air_Adam's Avatar
Ok, that makes sense... so if i got posi hunting, it does have to be out of the same type of axle, right? I'd have to find one in a 9 bolt to use in my 9 bolt axle?
Old Apr 20, 2003 | 10:16 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Count your bolts. I'd bet you have a 10-bolt. 9-bolts weren't introduced until 85. No such thing as "features from the future"!!
Posi wasn't too common in the older cars, nor were rear disk brakes. There's a good chance yours wasn't a posi, especially if it has drums.
RPO sheets usually aren't in cars that old; they didn't start leaving a copy of that until some years later.
I can't believe you're telling us that, and haven't even changed the fluid. Tomorrow, while you're doing that bit of long-overdue maintenance, which requires taking the cover off, make a point of looking at it to see if it has a posi in it.
Yes, and yes.
Avoid the ones in S trucks, affectionately known as the Eaton "Grenade Lock".
Old Apr 20, 2003 | 11:20 PM
MdFormula350's Avatar
yeah i do believe a 3.73 rear end from a 83 z28 would be a 10 bolt.
good luck in your search for a posi.
Old Apr 21, 2003 | 01:04 AM
Air_Adam's Avatar
The fluid was changed when i got it 8 months ago. My dad did that, but he doesn't remember if it had a posi (go figure, lol)
and yea, i knew it was either a 9 or 10 bolt, just couldn't remember (off day today, lol)
And when i have a chance, i'll check out some other f-bodies at the wrecker for a posi. They have lots of early 3rd gens there for some reason.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
mcgarnicle
Aug 12, 2015 04:58 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
