non thirdgen question
Old Apr 20, 2003 | 02:09 PM
d4nk's Avatar
Car: 86 T/A
Engine: 383
Axle/Gears: 3.27 9 bolt
Well my T/A is running fine so this weekend is time to fix my buddys jeepus. When driving down the road it'll run allright till it shifts then the rpms go up for a few seconds n then its like it finaly catches. It will do this threw each gear. Im not too fimiliar with the vehicle. its a 86 Jeep Charokee with a 2.8 n automatic tranny.
Old Apr 20, 2003 | 03:06 PM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
RPM flare between shifts, it probably needs a basic overhaul, though you can try changing the fluid and filter first...........................oh,and just so everyone else knows AMC/Jeep were idiots, yes, that truck has a chevy 2.8 v6, carbed, with a chrysler 904 trans behind it
Old Apr 20, 2003 | 03:42 PM
ede's Avatar
ede
i ahd a 79 jeep truck. it had 360 chrysler with ford carb and ignition, gm charging and starting system, th400 trans with dana rears. jeeps are bastards anyway you look at it.
as for you problem it may be something as simple as needing a filter change or low on fluid.
Old Apr 20, 2003 | 04:20 PM
jwattsjr's Avatar
Car: 84 & 86 T/A
Engine: LT-1 & 5.7L
Transmission: 700R4's
You might try OffRoad.com's Jeep section. From there you'll find links to XJ & ZJ (midsized Cherokees and Grand Cherokees)
forums, tech sites, and mailing lists. Like mentioned already, it could be as simple as a fluid/filter change, or, it may need
an overhaul.
ede, your J truck had an AMC 360 in it. And your right, they are bastards. I've got two.
-Jeff
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
redmaroz
Aug 16, 2015 11:40 PM
Exxon Limited
Aug 9, 2015 08:13 PM
