TH400 questions
Old Apr 20, 2003 | 06:01 PM
Camarothunder85's Avatar
Car: 1985 Camaro IROC-Z
Engine: 350ci V8
Transmission: 700-R4 auto
TH400 questions
I might end up building a 454 for my Z28. I know the 700-R4 will be disappearing soon , and I want to know how much power a stock TH400 will handle. Is it a direct bolt-in replacement for 700-R4? Is a new driveshaft going to be necessary?
Old Apr 20, 2003 | 06:15 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It is not a direct bolt-in. The crossmember will have to be moved; it will need a vacuum line to its modulator since it uses the sensilbe system of engine vacuum to determine the shift point instead of the stupidity of a cable; and it uses an electric kickdown switch (usually mounts on the gas pedal bracket).
The driveshaft will certainly need work. Apart from the length, it uses a totally different spline at the rear of the trans.
Here's a pic of the yoke splines for a Camaro, and one for a Turbo 400.
Attached Thumbnails TH400 questions-drive-shafts-t-400
Old Apr 20, 2003 | 06:37 PM
Engine: 350ci V8
This is going to be a royal pain in the @$$, isn't it?
Old Apr 20, 2003 | 07:19 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Hard to say..... the work is what it is, all the rest of that is all in your head
Old Apr 21, 2003 | 12:12 AM
Firebird355's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
ive got a vaccum modulator and a kickdown cable on my th350. heh
I still need a friggin driveshaft!! lol
Old Apr 26, 2003 | 05:44 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
i can help you with driveshaft, i have an 82 thm200c one and an 84 t/5/700r4/longtail th350 one here, 3" difference in length
im using neither because i am going with 400sbc and th400 shorty in the 82, i just got the 305 and thm200c yanked about 10 mins ago in the gravel, ! fun ! sarcasm !
but its out, yay !
now i can start cleaning and plannign for exhaust
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
