Rear axle question
Old Apr 21, 2003 | 12:46 PM
smoove2022's Avatar
Rear axle question
The rear axle on my 82 is toast. The bearings are going out and the diff creaks when going around corners slowly. I am thingking the best (cheapest) thing to do would be to swap out the axle for a good used axle from a salvage yard. My current axle has disk breaks, my question is if I bought a used axle with drum breaks, could I swap the disk breaks off of my current axle and put them on the axle with drum breaks?
Old Apr 22, 2003 | 08:19 AM
smoove2022's Avatar
someone help!
Old Apr 22, 2003 | 08:48 AM
FruityOne's Avatar
Car: 1989 TransAm GTA
Engine: One sweet modified 355 TPI.
Transmission: The kind that shifts....
I'd say contact 88 427 Camaro as I had similar problems before and he recomended a nice, cheap way to fix them.
So this is essentially a bump. If no one responds then contact him, vader, or ed miller. There are quite a few more people out there who could help you but those three seem to post helpful stuff the most.
Old Apr 22, 2003 | 11:11 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
disc to drum
the backing plates are different for the disc and drum brake systems.. you'll need to find a disc rear end to make the swap simple...
Old Apr 22, 2003 | 01:06 PM
smoove2022's Avatar
Thanks for the advice.
customblackbird
Aug 15, 2021 10:16 PM
draco
Oct 4, 2015 09:25 PM
E Rod
Aug 28, 2015 05:17 AM
red90IROCls1
Aug 25, 2015 06:56 AM
redmaroz
Aug 16, 2015 11:40 PM
