Yet another Detent cable question
Old Apr 26, 2003 | 01:29 AM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
Ok I read the tech article about how to set the TV cable, but I'm confused. What is meant by the metal "tang", and do I have to disconnect the cable from the TB? I'm not quite sure I follow what is stated there... this is for an L98 by the way. Any info appreciated.
Thanks,
Probably right in my face and I'm overlooking it.
Old Apr 26, 2003 | 03:29 AM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
The metal tang is the little D shaped metal piece on the side of the bracket that connects the cable to the throttle body. Just push it in with a screwdriver then slide the cable back toward the car. Put the throttle to the floor. You should hear a few clicks then your done.
Old Apr 26, 2003 | 04:34 PM
<-- Smacking forehead repeatedly.
Edit: Man I feel like an IDIOT. Never mind, I figured it out, it's so stinking easy. Of course, that's the way it always goes, right in front of my face.
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
redmaroz
Aug 16, 2015 11:40 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
