700r4 shifting
Old Apr 26, 2003 | 02:19 AM
radiateu2's Avatar
700r4 shifting
Can a modified engine change the timing of shifts in a 700r4 transmission. I am refering to the car in my signature. The car seems to shift fine from 1st to 2nd just after it shifts to second I wot it imediately kicksdown but wont up shift until about 6,000 rpm. Is something out of adjustment or did my engine mods change the shift characteristics
Old Apr 27, 2003 | 02:37 AM
radiateu2's Avatar
wow no one has a clue here?
Old Apr 27, 2003 | 06:16 AM
Pro Built Automatics's Avatar
When did the shifts occur before at WOT? When the TV cable is adjusted right, the transmission should make a 2-1 kickdown, (right after the light throttle 1-2 shift occurs) when you floor it.
Old Apr 27, 2003 | 08:44 AM
radiateu2's Avatar
Thanks for replying Dana,
The 2-1 shift occurs right after1-2 shift under light throttle then at WOT I have to let off the throttle a little otherwise the tranny wants to shift around 6,000 to 6,500 rpm and sometimes not shift at all untill I let off the throttle a little. I dont feel slippage, its a pretty firm shift when it shifts. I was wondering if a shift correction kit maybe in order. I have a good 2-1 kickdown right after 1-2 upshift. My second thought on this is maybe I have pump onits way out or some other problem with line pressure. The other thought I had is maybe I need to change my converter to a higher stall with the mods I have in my signature. Quite frankly its getting to be a pain in the a$$ and I almost tempted to go the TH 350 route. Finally I wonder if my governor needs to be recalibrated to compensate for the engine mods. I just dont know which way to go with this.
Old Apr 27, 2003 | 09:04 PM
ArrioZ28's Avatar
The trans should have near the same shift characteristics as before the engine mods, given that the TV adjustments are correct.
Does the trans have a normal upshift on other than wot?
I doubt that you have a pump going out. You'ld have lower line presure in that instance. It sounds like too much line presure.
It most likely is an adustment issue.
Old Apr 27, 2003 | 09:27 PM
radiateu2's Avatar
Hey Arrio,
Thanks for the imput. I used to live in Newport News off of Harpersville Rd.. I kinda miss the fishing lol. I was thinking about this all weekend. I think its an adjustment issue too. The 1-2 upshift on light throttle is pretty soft. I am hesisitant in making an adjustment on the TV cable without a guage. I may have to live with what I have since I cant get the bolt out of the guage port and a little too much line pressure maybe better than not enough, so they say error on the side of high in this instance.
loud91rs
Oct 5, 2015 10:05 PM
racereese
Oct 3, 2015 03:46 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
6998poncho
Sep 25, 2015 02:56 PM
