How do you remove the pilot bushing?
Old Apr 21, 2003 | 06:25 PM
thatsme's Avatar
I bought a pilot bearing to replace the bushing when I cange the clutch. I'm not exacly sure how to go about getting the old on out. A guy a work tolg me he packs it with greese and then uses a shaft that just fits into the hole. I guess by hitting the shaft you pressurize the greese and force the bushing out. It kind of sounds like it might work in principal or he could be just trying to cover me in greese to get a good laugh. Anybody else ever heard of this method, or have any others
Old Apr 21, 2003 | 07:27 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
He's not BSing you. He's obviously done one or 2 of them.
That's exactly how I do it. Keep adding grease as it comes out, you'll probably have to add grease 2 or 3 times before it comes all the way out.
Works every time. I know of no better way. Can't imagine how any other way could be better, actually, it works so well.
Let us know how it works for you.
Old Apr 22, 2003 | 03:52 PM
Fevre's Avatar
Car: 89 Formula
Engine: 355
I used a concrete bit that just fit in the hole and turned till it broke loss and it pulled right out while continuing to turn it. It helped I greased the bearing just a touch before install to make it easier to drive in.
Old Apr 22, 2003 | 06:00 PM
ede's Avatar
ede
i used the greese method for year till i bought a puller at a yard sale, now i use the puller
Old Apr 22, 2003 | 09:10 PM
JAYDUBB's Avatar
Car: 1991 Camaro RS
Engine: L03 305 V-8 (for now ;) )
Transmission: T-5 5 speed
Axle/Gears: stock... whatever that means :)
Grease method here too!
Old Apr 22, 2003 | 10:03 PM
ES87iroc's Avatar
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Can't beat the grease pack!
Old Apr 23, 2003 | 09:13 AM
Cronic3rd's Avatar
Car: 98 Z28 vert
Transmission: automagic
Axle/Gears: 2.73 - boo racing yay MPG
well I tried the grease method and squirted grease everywhere. I just borrowed a puller and a slide hammer from autozone.
Old Apr 23, 2003 | 01:48 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I tried that grease method. I packed the whole thing full of grease, got my wooden dowel in the hole, smacked it with a small sledge and almost killed myself when the sledge bounced back at me. No matter what I did I couldn't get enough grease in there to get all the air pockets out. I finally gave up, went down and bought a bearing puller. 2 minutes later my bearing was out. I'll never dick around with the grease method again. Not when a bearing puller works so quickly, easily, and CLEANLY.
Old Apr 23, 2003 | 02:14 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I have a couple of old clutch gears that I use.... a clutch alignment tool will work too.... I've never felt it worth the effort of getting another tool, the grease method works so well for me.
Maybe I just communicate with grease better than some people? One of those mind-meld things??
Old Apr 23, 2003 | 03:21 PM
ES87iroc's Avatar
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Perhaps so? Maybe it's just a personality trait, like being good with animals or something.
Old Apr 24, 2003 | 02:20 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
this is what I use, and it works great: SK PN 92522
Old Apr 27, 2003 | 10:40 PM
Z's r Best's Avatar
Car: '86 IROC, black and sharp
Engine: 305 tpi, bone stock
Axle/Gears: 3.42 pos w/rear db
I used to use grease. A couple of years back my brother in law told me to try soap. Take a bar of soap, cut some slices off with your pocket knife and push them into the bushing. Then use a wooden dowl (or an old input shaft) and drive the dowl rod in with your hammer. The soap is much more viscous than the grease and doesn't make a mess. One time convinced me. Try it, you'll like it.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
J-money
Jan 4, 2019 09:45 AM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
