DRIVESHAFT loop
Old Apr 26, 2003 | 10:09 PM
txhotRS's Avatar
DRIVESHAFT loop
OK, HOW is the driveshaft loop a "must for racing" (someone told me that)... What does it DO exactly, is it just incase you screwed someting up and you are expecting the driveshaft to come flying off at any second... Or is it to "guide" it.. ??
Old Apr 27, 2003 | 12:35 AM
waltersb's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Transmission: Auto 4
loop
There's mention of this on boards about what happens if you do a search...
if you are dragging, and your driveshaft comes appart at the front end.. it can drop into whatever you are driving on and send your car into a flip and *** know what else, and where it might go,... safety thing...
Old Apr 27, 2003 | 02:14 AM
BTS88IROC's Avatar
Unless you are making enough power to twist your DS apart you probably don't need it. Although anything can happen I guess and its always nice to have for extra insurance. Depending on where the DS breaks it does have the possibility of catapulting you I believe, if not its just gonna be swinging around and banging everything up, which isn't good either
Old Apr 27, 2003 | 08:02 AM
ede's Avatar
ede
safety item, i believe reqired for all cars running slicks
Old Apr 27, 2003 | 11:08 PM
25THRSS's Avatar
It is a requirement once you hit 11's. Probably won't ever need it but its better to be on the safe side.
Old Apr 27, 2003 | 11:35 PM
Dans_Zed's Avatar
Car: 85 Z28
Engine: 383
Transmission: TH350
Axle/Gears: 3.73 posi
According to IHRA or NHRA rules a driveshaft loop is mandatory on ANY car running slicks (no matter what ET). It must be bolted to the floorpan using a minimum of 4 x 3/8" bolts, located no futher than 6" from the front U joint and the loop must be made of min. 2" x 1/4" steel.
If you need it or not is up to you but none the less it still makes a hell of a safety feature for any RWD car.
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
loud91rs
Oct 5, 2015 10:05 PM
luvofjah
Sep 26, 2015 08:28 PM
Nick McCardle
Sep 10, 2015 08:36 PM
