rear end noises
Car: 86 T/A
Engine: 383
Axle/Gears: 3.27 9 bolt
rear end noises
Ive posted this msg before and still havnt gotten any reply's so i thought id post it again. Once the car has warmed up it starts to make a clicking sound coming from the rear end. More noticable when de-accelerating at like 20mph or slower. What i hear is a clicking sound then once the car has stopped it makes a loud clunk. I just replaced the u-joints & checked diff fluid level. It does have 100,000 miles on it. Could this be the signs of needing to rebuild the rear? Any input would be greatly appreciated.
Car: 86 T/A
Engine: 383
the clicking sound gets slower as the car slows. Then when the car stops it makes a loud clunk. If i get on the gas the sound goes away.
Car: 85 Camaro
Engine: 350 Carbed
Transmission: Stock 700r4
Check the torque are bushing. My car was doing that. If that dont fix it jack the rear up and move the back wheels back and forth with it in park. Watch the tailshaft and it might have to much play.
Hope this helps!
-Terry-
Hope this helps!
-Terry-
Car: Camaro RS
Engine: L03 305
Transmission: 700R4 Auto
It could be something with the play in the rear gears. Pull the cover off and manualy turn the rear to check for any abnormalities in the ring and pinion gears.
Re: rear end noises
Later
Engine: 4++,350 & 305 CIs
Re: rear end noises
If you have automatics the "clicking" your hearing, could be the governor weights.
A hard Clunk is another matter, I would check all your rear control arm, panhard rod, shock,torque arm and swaybar nuts and bolts. Even give your calipers and mounts a good once over if you have rear disc .
I have even seen a rotor and a drum move/clunk because of a wheel that wasn't torqued properly!
Car: 1987 IROC Original Owner
Engine: LB9
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
Re: rear end noises
Change the fluid in your rear and be sure to add the anti foaming agent to it.
Re: rear end noises
If you have automatics the "clicking" your hearing, could be the govenor weights.
Now, I will say that I do have to replace my sway bar nuts and bolts, so that may be causing the problem, but everything else you mentioned has been checked... Replacing soon, so if that takes care of the issue, I'll let you guys know...
Later
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
