Questions on 1993 T56
Old Apr 28, 2003 | 09:27 PM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
I've found a T56 for sale within reach of me for around 1400 bucks. It's a 1993 G92 Transmission
This is what I got from the seller:
Transmission 35k miles
Pedals
Master / Slave Cylinders
Crossmember
Bellhousing
Homemade Short Throw Shifter
McLeod Clutch and Pressure Plate w/ 4k miles
Stock Flywheel
Stock Clutch Fork..
I will leave all the plugs in the tranny for wiring.
Now my questions......
1) I'm going to be bolting this up to an 87 L98. Is there anything else I need for it to bolt up and run properly?
2) Are there any downfalls to this year transmission as compared to the 94+ years (keep in mind it is a G92) ?
3) How do the specs look as compared to other places/prices?
Thanks,
JON
Old Apr 28, 2003 | 09:31 PM
Car: 1987 GTA
Transmission: 4L60e
I found this information from the search...
Year 1st 2nd 3rd 4th 5th 6th
1993 3.36 2.07 1.35 1.00 0.80 0.62 (std)
1993 2.97 2.07 1.43 1.00 0.80 0.62 (G92)
1994+ 2.66 1.78 1.30 1.00 0.74 0.50
which was originally posted by Drakar.
How do these numbers pertain to drivability? Sorry for the noob question....gotta learn somewhere
Old Apr 28, 2003 | 09:35 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
the 93 is inherently the weakest T56 that was produced
Old Apr 28, 2003 | 09:48 PM
Car: 1987 GTA
Transmission: 4L60e
weakest as in 400 foot pounds....and this is the G92 version...so is it still JUST 400 foot pounds?
I'll never actually pass 400 foot pounds anyway, so this isn't a problem.
Old Apr 29, 2003 | 07:26 AM
quadgoat's Avatar
Car: 1992 Firebird
Engine: Stealth Rammed 412 with TC78 Turbo
Transmission: '93 T-56
Axle/Gears: 3.27 9 bolt posi with PBR discs
Well, I guess this isn't much of a help, but I haven't broken my '93 yet It's behind a fairly stout 350, but I've only got about 1000 miles on the whole package and the tranny was brand new when I put it in. I got the tranny, bellhousing, clutch fork and flywheel for $1,000 and even ended up getting free shipping on it hehe. According to the guy I bought it from it sounds like it's the G92 unit you were talking about with the 2.97 first gear. I have no complaints about the gearing, it goes along great with my 3:73 rear end. Anyway, I suppose I'm not helping out a whole lot, but I was told not to worry too much about the issue of it being a '93, if the price is right I'd say go for it, and it seems like a pretty decent deal you're getting. Most people say the only differences they know of between '93 and '94+ is the gear ratios, which shouldn't affect strength, although the '93 units are only rated at 400 ft. lbs. weird huh? Besides that, is a street car really gonna be running sticky enough tires to transfer 400 ft. lbs. straight to the ground? (those are basically the things that were said to me when I asked about the '93)
Hope this is a little useful
-Paul
p.s. here's the thread where I asked my question.
Old Apr 29, 2003 | 09:18 AM
Drakar's Avatar
all about the gears!!
Really the only diff is gearing, so if you think the gear spread is good then, go for it.
Here is a break down
Year 1-2 2-3 3-4 4-5 5-6
93 1.29 0.72 0.35 0.20 0.18 (std) (wide ratio)
93 0.90 0.64 0.43 0.20 0.18 (G92) (close ratio)
94+ 0.88 0.48 0.30 0.26 0.24
All depends on the gears and looking at the 94+ you can see why it is more desirable, but from the looks of it you're getting a good deal on your 93 G92 (I would verify G92) it should hold up well enough to your engine.
Old Apr 29, 2003 | 03:12 PM
Car: 1987 GTA
Transmission: 4L60e
:hail: thanks for all the help guys. I'd buy it if I could....but money problems have arisen. If anybody wants it, give the user: zimmstoy a PM or email. Great guy to deal with and he seems honest enough.
Warlocksirix
Sep 3, 2015 12:26 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
