Difference between 3.23 3.42 besides the ratio
Old May 6, 2003 | 08:00 PM
tbfirebird's Avatar
Car: Black 89 Formula
Engine: ??????????
Transmission: ??????????
Whats the biggest difference between 3.42 and 3.23 because i have the 3.23 but alot of people say that i should get 3.42.
So is there really a big difference im guessing that the 1/4 mile time would be a tenth or 2 slower if i used the 3.23
Old May 6, 2003 | 10:06 PM
Cuno's Avatar
If you are going to swap out gears, you will want to go with 3.73 gears from the 3.23 or you will not really notice a difference. I'm not sure how much of a track difference there would be...most likely not enough to make it worth while to swap in some 3.42 gears.
Old May 7, 2003 | 08:34 AM
82camaro's Avatar
Car: 82 camaro SC
The only difference between 3.23's and 3.42's is the ratio.
Old May 7, 2003 | 08:37 AM
85TPI400's Avatar
I think the people telling you to swap are wrong, It would not be worth the time or money swapping to the 3.42s. You would see very little gain from doing so.
Old May 7, 2003 | 11:59 AM
tbfirebird's Avatar
Engine: ??????????
think im just going to go with 3.42 i think it would make a difference because off the line a v6 xlt ford ranger 2001 got me for 3-4 seconds but them my v8 power pulled way past her.
Old May 7, 2003 | 12:19 PM
91Z28-350's Avatar
http://www.f-body.org/gears/
You want the gears to keep you in your powerband. This chart will give you an idea of what your speeds will be at given RPMs.
Old May 7, 2003 | 02:57 PM
Frik92RS's Avatar
Car: Camaro RS
Engine: L03 305
Transmission: 700R4 Auto
I went from 2.73 to 3.23 and when I did most people told me that I should've installed 3.42s. My opinion is that unless you are going from 2.73 the difference is not noticable for the cost of a gear change. Also, going with 3.73 like a lot of people will tell you to do would be a great gain for the track, but if your car is a daily driver and you like to cruise above 65 the 3.73s are a little too tall for you, that's why I went with 3.23, I like to cruise fast.
I actually almost miss the cruising at 100-110 with the 2.73s, hehe don't tell the cops
Old May 8, 2003 | 12:59 AM
jeffs82z28's Avatar
I had 3.23s' in my Z, but I went to the 3.42 and I like it a whole lot better.
IMHO, stay away from the 3.73 unless you have an overdrive trans.
My acceleration improved without sacrificing much top end.
I still cruise at 110 @ 5000 rpm. (some times when I've got a wild hair, I'll wind it up to about 125, but the motor is twisting almost 6000 rpm.
If you have the cash or parts and you want to improve the acceleration without sacrificing top end, go for it, I did and havn't regretted it.
But that is just my opinion, and I could be wrong
Hotrodboba400
Dec 10, 2019 07:07 PM
BAMiller
Sep 14, 2015 06:38 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
greenyone
Sep 2, 2015 03:39 PM
