POS shifter problem
Old May 8, 2003 | 01:20 AM
jeffs82z28's Avatar
POS shifter problem
My 1982 Z-28 has the 83mm borg-warner close ratio four speed, and the shifter mount either flexes too much to really jam the gears or it will work its way loose at the most in-opportune times.
Usually, while shifting, I can hit the clutch a little bit and shift from 1st to 2nd without any problem (an acceptable amount of gear clash), but when I go from 2nd to 3rd, the shifter feels like it is spring loaded and I have to wait for it to go into gear. The 3rd to 4th gear shift is good like the 1-2 shift.
During less vigorous shifting, the shifter does a fine job.
Does anyone have a suggestion for strengthening the shifter mount to eliminate the flexing and loosening?
I used locktite red the last time it got loose and that lasted about 8 months, but the flexing during the 2-3 shift is driving me nutso.
Thanks in advance.
Old May 8, 2003 | 07:58 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Replace it. Get a Hurst.
BewleyBizzIROC
Feb 3, 2020 09:52 AM
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
neekolzun
Aug 24, 2015 04:59 PM
