Can't remove alum driveshaft, help!
Car: Camaro RS
Engine: L03 305
Transmission: 700R4 Auto
I've got an Inland Empire alum driveshaft and I noticed that the rear seal on my tranny is leaking so I said "this shouldn't be too hard, I put the thing in there, I sure as hell can take it out to replace a seal, right?", wrong. I unbolted the retaining bolts on the yoke and tried to move it forward to pull it out of the yoke and it wouldn't move far enough. I've only got about 1/4" play in it until it stopped. I'm like, ooooooooook now what. Since I put it in I've had the gear changed to Richmod 3.23, would that have anything to do with this? Thanks for the help.
Car: `86 SS / `87 SS
The driveshaft will be further into the tranny when the rear is at full droop. So raise the car by jacking up the rear axle first of all. Second of all, wobble the u-joint in the rear in a variety of ways. I have an aftermarket alum. shaft in one of my cars and I have to wiggle the u-joint back and forth, and rotate the pinion yoke a bit to get it out. Not tough, just takes effort.
But, is your slip yoke going into the trans. far enough?
Car: Camaro RS
Engine: L03 305
The next time I'm under there I'll try jacking the rear back up into the car, I put the jackstands under the rear jacking points. I don't remember it being hard to install, but maybe I just got lucky or something.
I'm not sure what you mean by slip yoke but if its the one on the rear then I'm not sure. There is about 1/8-1/4 inch space between the rear end housing the the back of the yolk, since I don't remember how this was before I had the gears changed I have no reference to go off of.
Car: 1986 Firebird
Engine: 2.8 V6
I just helped out with this question...
Original message was in https://www.thirdgen.org/techbb2/sho...hreadid=178182
Remember, when you put your pry bar in there, don't be prying between the u-joint and the driveshaft!
They're attached. Pry between the axle and the u-joint.
Originally posted by TomP
The driveshaft might not budge when you take off the strap bolts for the u-joint at the axle; if so, just stick a pry bar in the u-joint "on the axle side", and pry against the pinion yoke to get the driveshaft to push "forward" into the rear of the trans.
If you're not going to replace the rear trans seal, before you do this job, put some new trans fluid on a rag. Wipe down the outside of the yoke right before it enters the tranny; get all the dirt off there. When you slide the new d-shaft in, put some new trans fluid on the outside of the new yoke.
They're attached. Pry between the axle and the u-joint. Thread
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
